rhett7660
Sep 16, 2018Aspirant
Exclude wired connection from Orbi list
I am using a BRB40 and on the connection list it is showing my MacMini is hardwired but it is also shows it is connected to Orbi. If this is the case, is there anyway to have it exclude the device? ...
- Sep 17, 2018
Ya, while in AP mode, there maybe some devices seen on the list. It's normal detection as it detects only what it's seen on the LAN side.
You'll be fine.
Sep 16, 2018Guru - Experienced User
What FW is currently loaded?
What is the Mfr and model# of the IP modem the Orbi is connected too?
How is the system all connected together from the ISP modem?
- rhett7660Sep 16, 2018Aspirant
Firmware: V2.1.4.16
Orbi Model BRB40 set to AP Mode
Manufacture of FiOS Modem: Verizon FiOS-G1100 Firmware: 01.04.00.10-FTR (Latest version as there is no update pending)
FiOS is handling the DHCP, WiFI is turned off. Used to access the internet
Orbi is connected to FiOS and is set to AP Mode
