rhett7660
Sep 16, 2018Aspirant
Exclude wired connection from Orbi list
I am using a BRB40 and on the connection list it is showing my MacMini is hardwired but it is also shows it is connected to Orbi. If this is the case, is there anyway to have it exclude the device? ...
- Sep 17, 2018
Ya, while in AP mode, there maybe some devices seen on the list. It's normal detection as it detects only what it's seen on the LAN side.
You'll be fine.
Sep 16, 2018Guru - Experienced User
Ok, probably something that will show up on the Orbi connected clients list....I would not pay too much attention to it...
- rhett7660Sep 16, 2018Aspirant
Gotcha. Just wanted to make sure it wasn't actually connected to the orbi, but rather just showing up as a connected to device on the network.
- FURRYe38Sep 17, 2018Guru - Experienced User
You'll be fine.
