Doug427
Apr 06, 2021Follower
existing OrbiRSB40V stopprd working
Ref: RBR20 Router with RBS40V Extender - I have been using the Extender's Ethernet for my PC for 2 years. - Ethernet became intermittent, then stopped working. (error = cable not connected) - RBR...
smachaje
Jun 03, 2021Tutor
I had similar experience with RBS40V, not the extender version.
Check the firmware on the router. It should not be higher than the satelite. I just spent a day trying to figure out why my RBS40V with firmware 2.6.2.4 couldn't connect to RBR40 with 2.7.2.104. I had to downgrade firmware on the router first to 2.6. But wait for it, Netgreat suggested for automated firmware update the 2.7!!! For RBS40V 2.6 is the last firmware available. So 2.7 on router basically kills RBS40V satelites.
