AndySNZ
May 03, 2020Aspirant
Existing wifi router setup with orbi
Orbi newbie here - just set up AC2200 3 pack - works fine but I’m plugging into existing modem/wifi router and still seeing “old” wifi as well as new one. 1 is that a problem and have I set it up wron...
AndySNZ
Much appreciated - double NAT - at least I know it has a name :) I’ll see if my ISP can get the modem/ router to “bridge mode” - I need to keep the original device because it has a VOIP phone running of it as there is no cell service here....
May 04, 2020Guru - Experienced User
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- timchMay 04, 2020Luminary
Given the VOIP service I think your easiest way home is use option 3 above. You lose some of Orbi's functionality but you allow it to do what it does best in my opinion, provide seamless WiFi.
