starnz
May 28, 2019Aspirant
Expand existing Orbi Home system with Orbi Pro
I have an existing Orbi Home system (RBK50) and would like to expand it using an Orbi Pro (SRK60) system. Will the two systems be able to be used in one mesh system?
May 28, 2019Guru - Experienced User
No. RBRs can only operate in router mode and AP mode. You can't combine two systems together.
- starnzMay 28, 2019Aspirant
So does that mean the two units from one system can not be set up to be satelites to the other system? One main router with three satelites?
