Kssmith's avatar
Kssmith
Follower
Jun 20, 2019
Expandable WIFI area
When I bought the router and satalite it  stated it could be expanded up to 4.  Can you buy additional satalites or will it connect to another router and its satalite?\ Thanks, Kevin
  • schumaku's avatar
    Jun 20, 2019
    Additional satellite(s)s of the same/similar type/WiFi technology level and the outdoor satellite(s) only. Another Orbi router or Orbi kit can't be added.
