Kssmith
Jun 20, 2019Follower
Expandable WIFI area
When I bought the router and satalite it stated it could be expanded up to 4. Can you buy additional satalites or will it connect to another router and its satalite?\ Thanks, Kevin
- Jun 20, 2019
Additional satellite(s)s of the same/similar type/WiFi technology level and the outdoor satellite(s) only. Another Orbi router or Orbi kit can't be added.
schumaku
Jun 20, 2019Guru - Experienced User
CrimpOn
Exactly right. If you purchase another "kit", the router cannot be used as a satellite. There are other possible uses for it, such as an Access Point with a different WiFi name, sell it, or give it to someone.
