KaketheFinn
Apr 12, 2021Follower
Expanding Orbi RBK752 with another RBK752
Hi folks I've got this problem. Have RBK752 mesh (router and one satellite). Now I need to expand my wifi network. I do know that buying single satellites is the easiest solution. Also the most expe...
Apr 12, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Orbi AX product. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you.
KaketheFinn wrote:Hi folks
I've got this problem. Have RBK752 mesh (router and one satellite). Now I need to expand my wifi network. I do know that buying single satellites is the easiest solution. Also the most expensive. Most likely I need two more satellites. So, what if I buy another set of RBK752. Can I use new router as an satellite? I know that someone has already asked the same question. He/she got an "nope" answer. But I have wired home network in addition. And I could connect this new "router"(RBR752) to my existing system via cable(cat6). If I do so, will this new RBR752 work as an satellite in my current wifi ?
Single satellite will cost me about 290€, and RBK 752 set (router and satellite) about 380€.
Brgds
Kake
- vajimApr 13, 2021Master
FURRYe38 wrote:Netgear has set up a community forum specifically for the Orbi AX product. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-axThank you.
Brgds
Kakethose of us ...??
