KenLoc
Oct 30, 2019Aspirant
Expanding ORBI RBR50 system
I have a system comprised of an RBR50 router and an RBS50 satellite. To expand my coverage I bought an RBW20 to plug into a wall socket. I wanted to extend the system in a straight line ie from RBR...
Oct 30, 2019Guru - Experienced User
How far apart are they? They need a minimum of 30 ft between then to function appropriately.
Also is daisy chain mode enabled in your settings? This needs to be enabled for them to function as you desire.
What firmware is each device on?
KenLoc
Thanks for your help. The RBS50 is about 40 ft from the RBR50. This setup has always worked fine. The new RBW30 is about 50 ft from the RBS50 and about 80ft from the RBR50 (hence the weak connection (in different rooms). The RBR50 firmware is v2.5.0.38. The RBS50 is the same. The RBW30 is V2.3.5.6.
The RBS is connecting to the RBR at 5Ghz and the RBW is connecting to the RBR at 2.4Ghz.
I am using the Orbi app (latest version) on an iPhone 7 but cannot find anywhere in settings that allows me to enable daisy chain mode. Can you point me to the correct place to do this?
- plemansOct 30, 2019Guru - Experienced User
here's what it means.
https://kb.netgear.com/000048458/What-is-daisy-chain-and-how-does-it-work-with-my-Orbi-WiFi-System
Page 58 of the manual has the walk through but its in this location: ADVANCED > Advanced Setup > Wireless Settings
one thing to check is if there's anything in between the satellites. Brick, concrete, adobe, foil lined insulation, and hvac all block signals. If its falling back to the 2.4ghz signal something might be blocking signals. if you're house is a standard wood/sheetrock house, try moving the satellite a little as maybe hvac within the walls is blocking.
- KenLocOct 30, 2019Aspirant
There are walls between the RBW and the router it is connecting to, but only gyprock. However the walls and the distance (80ft) may be causing the signal to default to 2.4Ghz. There is nothing between the two satellites. They are at each end of a long room (50ft in length).
Try rebooting the system. Shut everything off. Then turn on the router. Wait a few minutes, turn on the rbs50, wait for it to fully boot, and then try the rbw. It should dynamically balance out but stranger things have happened.
I went in through the orbilogin website and found the daisy chain setting. It was already enabled.
- Retired_MemberOct 30, 2019
Here's your problem: v2.5.0.38.
As well as be careful with your understanding of network extension.
- FURRYe38Oct 30, 2019Guru - Experienced User
Has a factory reset and setup from scratch been performed since last FW update? This has helped others with odd issues. Last resort to try.
KenLoc wrote:Thanks for your help. The RBS50 is about 40 ft from the RBR50. This setup has always worked fine. The new RBW30 is about 50 ft from the RBS50 and about 80ft from the RBR50 (hence the weak connection (in different rooms). The RBR50 firmware is v2.5.0.38. The RBS50 is the same. The RBW30 is V2.3.5.6.
