stevefxp's avatar
stevefxp
Apprentice
Apr 30, 2019
Explicit MAC Filtering
Hello all, Is there a way to explicitly exclude a MAC from connecting to my Orbi Wifi? I do not see a way to enter a MAC, so that it would be excluded.   Thanks, Steve
  • CrimpOn's avatar
    Apr 30, 2019
    I think this is the intended purpose of Access Control.  Under the "Advanced" tab, select Security, then Access Control.  At the bottom of the screen is where devices which may NOT connect are entered by MAC address.
    (Caveat) My understanding is that Access Control was reported not to work correctly in previous firmware versions.  I have never tried it (before today).  I am not charging an old smartphone, have entered the MAC address into the table, and will "see what happens" once it gets charged.
