Masmas112
May 19, 2022Follower
Export settings from RB20 to import in RB50?
Hello everyone, I am about to update from RB20 to a RB50. Does anyone know if I can export the settings from my RB20 and import them in the RB50? I have quite a lot of address reservations so I i...
May 19, 2022Guru - Experienced User
I wouldn't. Its different hardware. We usually don't recommend using a backup unless using the same exact router. I don't even recommend it if going through different versions of the same hardware.
