Chill25769
Feb 07, 2023Follower
ExpressVPN on RBR50
I have an RBR50v2 how can I use ExpressVPN or does it have a built in VPN and if so how do I setup secure VPN on my router?
CrimpOn
Feb 08, 2023Guru - Experienced User
There are always two parts to VPN:
- A VPN Server which accepts connects from one or more
- VPN Clients and creates an encrypted "tunnel" between each Client and the Server.
Any number of client devices (computers, smartphone, tablets, etc.) on the Orbi LAN can load any VPN Client they want and connect to the VPN Server which supports that client. (i.e. NordVPN, ExpressVPN.... there are dozens of VPN servers.
Netgear routers support one VPN Server package: OpenVPN. See page 121 of the User Manual:
https://www.downloads.netgear.com/files/GDC/RBK50/Orbi_UM_EN.pdf
This allows remote OpenVPN clients (in a coffee shop, at a friend's house, at a hotel, etc.) to open an encrypted connection from that location to the Orbi LAN in order to access devices on the LAN (including the router itself). One creative person posted about using the VPN capability to make it appear that he was at home in order to access video streaming that was blocked at his physical location. (probably a "sin" of one sort or another)
So, if the goal is to have home devices bundle all their connections to the internet through a VPN, the answer is "no". Not with Express VPN. Not with OpenVPN. Just "no".
(You probably already discovered this information already, but once I get typing there is no going back.)
