sherbear97124
Aug 06, 2020Aspirant
Extend Orbi Outdoor signal for cameras
I have the Orbi RBR50 with the 2 indoor satellites plus one Orbi Outdoor satellite. The outdoor satellite is accessing the Orbi router directly. Sadly, our place is "blessed" with a whopping 18Mbps o...
michaelkenward
Aug 07, 2020Guru - Experienced User
Mstrbig wrote:
First off WIFI 5G will not help you as it has a shorter distance disadvantage over 2.4G which offers coverage for farther distances.
Maybe they mean 5G mobile rather than 5 GHz wifi.
5G technology is, indeed, designed to fill IoT gaps, but the wait might be long, especially if President Trumps gets his way.
Mstrbig
Aug 07, 2020Master
michaelkenward wrote:
Mstrbig wrote:First off WIFI 5G will not help you as it has a shorter distance disadvantage over 2.4G which offers coverage for farther distances.
I thought so too as well. But after thinking about it 5G Cellphone service 5G, the cameras would have to support directly connecting to the Cellphone carrier's 5G network or the same distance problem would still exist.
One other thing I thought of would be to change out the camera antennas with more powerful higher db gain antennas. If I remember correctly the standard antenna is less than 3db. Increasing to 9db should help. Terrain would come into play. The flatter the terrain between devices the better. They are not that expensive so it may be worth a try.
