sandman512
Feb 12, 2020Apprentice
Extend Orbi wifi(details within)
So, just installed the RBK53S-100NAS in my house. I was able to successfully wire up the satellites. The signal strength is good , no issues except one spot, out in my garage. I am not able to mov...
Feb 12, 2020Guru - Experienced User
Run a LAN cable closer towards the garage and move a RBS closer if possible.
Run a LAN cable out to the garage and put an RBS there.
What is the distance from the garage to the house or from garage to closest RBS?
- sandman512Feb 12, 2020Apprentice
House is 3000 sq/ft. The distance from the router to the satellite is approx 35-35 feet, but they are daisy chained. The distance from the RBS to the garage is 40 feet, BUT goes through a few wall/doors. I could run a cable to the garage, but there are two concerns. First, will I sacrifice WiFi in the room/area where I need it first. Second, the garage can range in temp being that I live in the NY. Thank you!
- FURRYe38Feb 12, 2020Guru - Experienced User
No.
Look at the specs of the RBR or RBS in the spec sheet. See if temps are with in operation range. You could put a laptop cooler under the RBS if placed in the garage.
Ok, thanks, I'll give a look. I was curious if I could get a NETGEAR Wifi Range Extender EX3700 and just plug in a cable from the closet satellite to this extender since it has a Ethernet port.
