Mundorff
Nov 28, 2021Aspirant
Extend Range of Orbi RBK50 System
We have an exiting Orbi RBK50 mesh sytem in our single story 3400 sq-ft home. I want to extend our wifi coverage to our detached garage. Can I use a Netgear power line adapter system to connect the O...
- Nov 29, 2021
Mundorff wrote:
Thank you for taking the time to reply. It has given me something more to think about. Do you have any experience with the performance capability of daisy chaining Orbi satellites?
Alas, no. All of my satellites connect directly to the router. There have been many posts on the forum describing a "Daisy Chain" being successful.
CrimpOn
Nov 28, 2021Guru - Experienced User
Yes..... and "Maybe".
The good part about PowerLine is that the devices all sense that they are connected to an ethernet cable. They have (literally) no way to know that they are actually using a different technology to get from point to point. The satellite will sense an ethernet connection (should be gigabit port) and switch to wired backhaul.
The bad part about PowerLine is that the performance varies tremendously based on distance, interference, and the quality of the wiring.
I now have three TP-Link PowerLine adapters installed. PowerLine reports the 'link speed' between A and B as between 900 and 1,200mbs, but the link between A and C is only from 380 to 400. (It varies from minute to minute.)
PowerLine is similar to WiFi in that only one device can broadcast on the wire at a time. And PowerLine has the same sorts of 'overhead' that WiFi does. (broadcasts, request to send, checksums, etc. etc.) The effect throughput on PowerLine may be only half of what their 'link speed' claims. Fortunately for me, I am using this link to feed a DVR and even 100mb would be more than adequate.
Originally, I had four PowerLine units with the 4th one supporting IP security cameras mounted on my garage. But that unit kept going off line and the unreliability was so frustrating that I bought an Orbi RBS40V (they were about $99 for a while.).
- MundorffNov 29, 2021Aspirant
- CrimpOnNov 29, 2021Guru - Experienced User
