michaelcdbarnes
Jan 12, 2021Aspirant
Extend RBK53
Hi, I have an RBK53 and need to buy an additional satellite purely so my daughter can have Ethernet point in her study. I have going to buy another RBS50 but they don't seem to be available. How can ...
Jan 12, 2021Guru - Experienced User
Your system can also use:
RBS20, RBW30 (no ethernet port), RBS40, RBS40V (smart speaker), RBS50, RBS50Y (outdoor), and the EX7500/7700/8000
The RBS40V tends to be the cheapest option as you can usually find it on sale for around that $100
- michaelcdbarnesMay 19, 2021Aspirant
Hi, As I just need an ethernet port is there a smaller device I can purchase rather than a large satelitte? thanks
- plemansMay 19, 2021Guru - Experienced User
You can look through the compatible models that I listed. thats what works with it
- CrimpOnMay 19, 2021Guru - Experienced User
michaelcdbarnes wrote:Hi, As I just need an ethernet port is there a smaller device I can purchase rather than a large satelitte? thanks
I have used a Netgear EX3700 for this purpose.
https://www.downloads.netgear.com/files/GDC/EX3700/EX3700_EN_QSG_04_10Mar2015.pdf
This is not a "satellite" in the sense of being part of the Orbi "mesh" where WiFi devices will roam between it and the other Orbi units, but it has an ethernet port so that a device (such as a computer or television) can be connected.
