  • CrimpOn's avatar
    CrimpOn
    Yes, it will.  You will want to use the "Orbi" firmware, not the "extender" firmware.
    Quite a good deal, considering the lowest price on Amazon is $169.95
      • FURRYe38's avatar
        What you need to do is factory reset the RBS. Wire connect a PC to the 1st satellite. Already have the most current FW version files downloaded on to this PC.
        Wire connect 1 PC to the back of the RBS. Factory reset the RBS, wait about 5 minutes. The PC will get a IP address from the satellite. The RBS will be 192.168.1.250. Use this IP address in a web browser to log in to the satellites web page. Log in as admin and password. Use the satellites web page FW update feature to select the FW update file that was unpacked from the .zip file. Then factory reset and then re-sync the satellites to the RBR.
