rsm2000e
Jul 25, 2019Aspirant
Extend Wifi to an outbuilding what hardware needed?
Moving to a flat above the garage, about 50 feet from main house. Have a 2-piece Orbi RBR20 unit, thinking I might need more hardware to boost the signal in my new apartment (a 2 room setup). My ex...
CrimpOn
Jul 25, 2019Guru - Experienced User
Will the landlord let you place your Orbi router "in the window" (literally, so there is not a brick wall for the signal to pass through)?
You can mitigate affecting his WiFi by setting yours to a channel with zero overlap with his.
You can also reduce the transmit power on your WiFi signal (on one of the Advanced menus) Alas, I know of no way to affect the "user side" WiFi signal level of only the router.
My guess is that the "backhaul" radio signal is the critical factor. There is a method using telnet to control the radio signal level:
https://community.netgear.com/t5/Orbi/Further-Reduce-the-Transmit-Power-in-Orbi/m-p/1672260
rsm2000e
Jul 26, 2019Aspirant
Posts I have come across say while Orbi is 'fine' inside a contiguous structure, it is "less fine" when long distances between structures become involved. To give an example, inside the landlords house using a regular Netgear cable modem, the signal strength from upstairs to downstairs is approximately -74db out of a possible -24db max this is about a 50% drop in signal strength for just downstairs vs upstairs where the router is. Walk outside go into my apartment over the standalone garage and a 300 mbps signal drops to like 15 mbps because of the distance and the physical structures (windows closed).
Goal: to avoid paying stupid money to Comcast (landlord is close personal relative and is willing to let me an 'extra room' on his comcast bill with my own UHD Comcast box ($10 a month). That's great, but no Internet to speak of.
Running a Cat 6 cable could work well, but physically improbable as it woud be ugly hanging in space between the buildings.
Frustrated!
- FURRYe38Jul 26, 2019Guru - Experienced User
Any chance of burying the LAN cable?
Orbi can only do so much distances.
Might be best to get your own internet...
- CrimpOnJul 26, 2019Guru - Experienced User
An gigabit ethernet cable can be up to 90m, which means it could take a "roundabout" path from house to garage and still be within specs. There is outdoor rated Cat6. Your observations about how 2.4G and 5G penetrate structures are correct. A brief Google search turned up refererces to how 2.4G and 5G penetrate different materials: https://www.am1.us/wp-content/uploads/Documents/E10589_Propagation_Losses_2_and_5GHz.pdf
I skipped over all the formulas to the end where it appears that things like brick, wood, and stucco have several times the attenuation that glass does.
Are you able to mount things to the outside of these buildings? Several community members have reported using Ubiquiti Nanostations to bridge between the main house and other structures. There is one model that is powered over PoE, which means only the ethernet cable has to penetrate the building wall. In essence, using a pair of wireless units create the same result as running an ethernet cable. The electronics on each end have no idea that they are not talking over ethernet.
- rsm2000eJul 26, 2019AspirantMy landlord is 80 yr old friend of a friend. I don't want to stress him out. The home routers do not provide phantom power for PoE. I would need a pricey switch for that no deal. I know about the type of solution you mention I will call a vendor who put in outdoor WiFi commercial boosters in our car dealership. It was quite pricey. I had a thought about Orbi but I think it's outside Orbi world.
Here's the product page for Nanostations: https://www.ui.com/airmax/nanostationm/
I looked up one of them on Amazon, and people talked about installing them "indoors" instead of outdoors on a pole mount. I guess if they will carry 10km, they will probably get through a wall or two and go 75ft. A package of two, complete with PoE injectors is under $150US. One end would plug into the landlord's router and the other end would plug into any old brand of Access Point.
