rsm2000e
Jul 25, 2019Aspirant
Extend Wifi to an outbuilding what hardware needed?
Moving to a flat above the garage, about 50 feet from main house. Have a 2-piece Orbi RBR20 unit, thinking I might need more hardware to boost the signal in my new apartment (a 2 room setup). My ex...
CrimpOn
Jul 26, 2019Guru - Experienced User
An gigabit ethernet cable can be up to 90m, which means it could take a "roundabout" path from house to garage and still be within specs. There is outdoor rated Cat6. Your observations about how 2.4G and 5G penetrate structures are correct. A brief Google search turned up refererces to how 2.4G and 5G penetrate different materials: https://www.am1.us/wp-content/uploads/Documents/E10589_Propagation_Losses_2_and_5GHz.pdf
I skipped over all the formulas to the end where it appears that things like brick, wood, and stucco have several times the attenuation that glass does.
Are you able to mount things to the outside of these buildings? Several community members have reported using Ubiquiti Nanostations to bridge between the main house and other structures. There is one model that is powered over PoE, which means only the ethernet cable has to penetrate the building wall. In essence, using a pair of wireless units create the same result as running an ethernet cable. The electronics on each end have no idea that they are not talking over ethernet.
rsm2000e
Jul 26, 2019Aspirant
My landlord is 80 yr old friend of a friend. I don't want to stress him out. The home routers do not provide phantom power for PoE. I would need a pricey switch for that no deal. I know about the type of solution you mention I will call a vendor who put in outdoor WiFi commercial boosters in our car dealership. It was quite pricey. I had a thought about Orbi but I think it's outside Orbi world.
- CrimpOnJul 26, 2019Guru - Experienced User
Here's the product page for Nanostations: https://www.ui.com/airmax/nanostationm/
I looked up one of them on Amazon, and people talked about installing them "indoors" instead of outdoors on a pole mount. I guess if they will carry 10km, they will probably get through a wall or two and go 75ft. A package of two, complete with PoE injectors is under $150US. One end would plug into the landlord's router and the other end would plug into any old brand of Access Point.
p.s. I am not "pushing" Ubiquiti. Several community members have mentioned that product. Amazon is happy to suggest lots of other brands. And, a Google search might even turn up better alternatives.
- rsm2000eJul 27, 2019Aspirant
So the Ubiquiti units are not true 'wi-fi' yes? They are acting as Ethernet "bridge" so I would plug the receiving side into my Orbi access point?
Thank you for taking the time and trouble to try to come up with a viable solution. I imagine this 'issue' is fairly frequent as separate 'flats' or other outbuildings are becoming the norm in home construction as parents age. When the parents pass on, then the outbuildings are a source of ongoing rental income and the benefit is the landlord is very much eyes-on his rental unit!
- CrimpOnJul 27, 2019Guru - Experienced User
Yes indeed. These Ubiquiti (and similar) units have a three-way selector switch and "bridge" is one of them. The maximum throughput on these particular units is 150mb. Not equal to an Orbi backhaul, but possibly enough to get by. And, it is interesting that they seem to have the same throughput no matter whether they are using 900MHz, 2.4G, or 5G.
If you decide to try a product like this, please post the results. As you said, this is becomming a very common issue on the forum.
