rsm2000e
Jul 25, 2019Aspirant
Extend Wifi to an outbuilding what hardware needed?
Moving to a flat above the garage, about 50 feet from main house. Have a 2-piece Orbi RBR20 unit, thinking I might need more hardware to boost the signal in my new apartment (a 2 room setup). My ex...
CrimpOn
Jul 26, 2019Guru - Experienced User
p.s. I am not "pushing" Ubiquiti. Several community members have mentioned that product. Amazon is happy to suggest lots of other brands. And, a Google search might even turn up better alternatives.
rsm2000e
Jul 27, 2019Aspirant
So the Ubiquiti units are not true 'wi-fi' yes? They are acting as Ethernet "bridge" so I would plug the receiving side into my Orbi access point?
Thank you for taking the time and trouble to try to come up with a viable solution. I imagine this 'issue' is fairly frequent as separate 'flats' or other outbuildings are becoming the norm in home construction as parents age. When the parents pass on, then the outbuildings are a source of ongoing rental income and the benefit is the landlord is very much eyes-on his rental unit!
- CrimpOnJul 27, 2019Guru - Experienced User
Yes indeed. These Ubiquiti (and similar) units have a three-way selector switch and "bridge" is one of them. The maximum throughput on these particular units is 150mb. Not equal to an Orbi backhaul, but possibly enough to get by. And, it is interesting that they seem to have the same throughput no matter whether they are using 900MHz, 2.4G, or 5G.
If you decide to try a product like this, please post the results. As you said, this is becomming a very common issue on the forum.
