johnniej
May 14, 2018Tutor
Extend WiFi to the garage
I need some advice on the best product to extend the Wifi to my garage. I'm currently using the RBK53 system.
The garage is a separate brick building about 25 feet away from the house. Currently if...
May 14, 2018Guru - Experienced User
You might try them both as demo to see what works best. Find something online or at a local store that has a good refund policy.
Seen some users with problems with the RBW30 and the 50 series.
Starting point distance between the router and a satellite is about 30 feet. Upwards to 50 feet.
- johnniejMay 14, 2018Tutor
Hi,
I think I might just try the RBW 30 and I will get it from Amazon and if it doesn't do what it's supposed to then send it back and try the other from Costco.
Thanks for the advice
- FURRYe38May 14, 2018Guru - Experienced User
Let us know how it goes...
- johnniejMay 21, 2018Tutor
Hi,
I bought the RBW30 and it works fine.
I paired it up in the house and took it out to the garage and it works well.
Getting 585 mbps out there and that's through 2 brick walls.
It's probably about 30 to 40 feet from the router in the house.
I will say it's a pain to pair up but once I got it it works fine.
Thanks
