johnniej
May 14, 2018Tutor
Extend WiFi to the garage
I need some advice on the best product to extend the Wifi to my garage. I'm currently using the RBK53 system.
The garage is a separate brick building about 25 feet away from the house. Currently if...
johnniej
May 14, 2018Tutor
Hi,
I think I might just try the RBW 30 and I will get it from Amazon and if it doesn't do what it's supposed to then send it back and try the other from Costco.
Thanks for the advice
May 14, 2018Guru - Experienced User
Let us know how it goes...
- johnniejMay 21, 2018Tutor
Hi,
I bought the RBW30 and it works fine.
I paired it up in the house and took it out to the garage and it works well.
Getting 585 mbps out there and that's through 2 brick walls.
It's probably about 30 to 40 feet from the router in the house.
I will say it's a pain to pair up but once I got it it works fine.
Thanks
- Retired_MemberMay 22, 2018
johnniej wrote:
Hi,
Thanks
how's the garage insulation? Temps during winter/summer?
- johnniejMay 22, 2018Tutor
Fully heated with running water. I have a shop out there that I work out of.
Should be good.
