johnniej
May 14, 2018Tutor
Extend WiFi to the garage
I need some advice on the best product to extend the Wifi to my garage. I'm currently using the RBK53 system.
The garage is a separate brick building about 25 feet away from the house. Currently if...
johnniej
May 22, 2018Tutor
Hi,
I bought the RBW30 and it works fine.
I paired it up in the house and took it out to the garage and it works well.
Getting 585 mbps out there and that's through 2 brick walls.
It's probably about 30 to 40 feet from the router in the house.
I will say it's a pain to pair up but once I got it it works fine.
Thanks
Retired_Member
May 22, 2018
johnniej wrote:
Hi,
Thanks
how's the garage insulation? Temps during winter/summer?
- johnniejMay 22, 2018Tutor
Fully heated with running water. I have a shop out there that I work out of.
Should be good.
