Soundman213
Jul 28, 2023Follower
Extender compatibility with a RBR50v2 router.
I have the RBR50v2 router and RBS50 satellite now. I'd like to add one more satellite, but the price point of the RBS50 isn't justified by my needs. Walmart has a clearance on the RBK50 that includes...
Jul 28, 2023Guru - Experienced User
More than likely its one of the satellites if the router is the RBR50.
But there's other version you can use.
Here's the orbi compatibility chart.
https://kb.netgear.com/000065169/Which-Orbi-routers-and-satellites-are-compatible
