Bobh1072
Nov 21, 2018Follower
Extender Models
 Considering the RBK 50 or RBK 23 but I might need to use and extender because I’ve found it very difficult to get coverage throughout my house, especially on my covered porches. My cell coverage is a...
Nov 21, 2018Guru - Experienced User
If you get a orbi system, you shouldn't need an extender. First off, What is the size of your home? Sq Ft?
 30 feet is recommended in between Router base and satellite(s) to begin with depending upon building materials.
I have a 5000sq ft home and use just a base and 1 satellite and have great coverage and performances inside and out.
- schumakuNov 21, 2018Guru - Experienced User
Adjust the satellite position, or add additional Orbi satellite(s) near to the covered porches.
