Lethal57
Apr 07, 2019Guide
Extending coverage
Hi, I have placed my R6400V2 next to the ISP supplied modem/router, which wont cover more than 5 metres (poor tech choice by isp).
They seem to work ok together (bandwidth/frequency wise).
W...
Apr 07, 2019Guru - Experienced User
Wondering if the Netgear ac2200 (rbk30) would work with the R6400V2
Looking forward to further advises
Lethal
So what you're trying to do is this?
ISP modem-->R6400v2-->RBK30
What I'd try to do is go:
ISP modem/router--->RBK30
See how that works. the RBK30 should cover around 3500 square ft if setup properly. How much area are you trying to cover? If it doesn't cover enough, you can add the r6400v2 back in. In my opinion, simpler is better as it reduces conflict or chances of failure.
If you get the Orbi set, I'd shut off the wireless on the isp supplied device unless you really need it.
