Lethal57
Apr 07, 2019Guide
Extending coverage
Hi, I have placed my R6400V2 next to the ISP supplied modem/router, which wont cover more than 5 metres (poor tech choice by isp).
They seem to work ok together (bandwidth/frequency wise).
W...
michaelkenward
Apr 07, 2019Guru - Experienced User
If you have the R6400V2 sitting next to a modem/router that also delivers wifi, then you shouldn't need the wifi from the modem.router. Best turn it off.
If the R6400V2 doesn't cover five metres, then something is wrong.
You should not need anything else to go that far.
If you don't own the RBK30 already, before spending money on more equipment, I'd put a bit of effort into setting up what I already own.
It might help if you told people what the modem is in front of this router. The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
That it the ISP's box supplies wifi suggests that it is a modem/router. Two routers on your network can cause headaches. This might screw up your existing wifi sources.
- plemansApr 07, 2019Guru - Experienced User
I think the OP is stating that the ISP's equipment won't cover more than 5 meters, not the R6400v2. I could be wrong though.
- michaelkenwardApr 07, 2019Guru - Experienced User
Who knows?
But plugging the R6400v2 into a modem/router means that they probably have two wifi sources sitting next to each other. Not a good idea.
Who knows?
Agree 100% with that. Never good to have 2 devices broadcasting if you can help it. its why i wouldn't add the orbi into the mix without shutting off wifi on the ISP supplied device and not hooking up the R6400v2 unless needed. Thanks for helping clarify for the OP
- Lethal57Apr 08, 2019Guide
Hi
Thanks muchly for your contribution/response. Indeed thank you all for your responses!
Just how would you "If you don't own the RBK30 already, before spending money on more equipment, I'd put a bit of effort into setting up what I already own.'???
The ISP Modem is a Sagemcom AC WiFi modem. If this helps...
I have had issues with it previously whilst a cable customer of the same isp, their NBN model is worse!
Secondly, the r6400v2 does not unfortuntely support VOIP...hence the need for the isp modem (which does).
Looking forward to your response
- michaelkenwardApr 08, 2019Guru - Experienced User
I don't understand. What's the question?
Like I said if you don't own the RBK30, spend some time setting up the R6400V2.
That is not much help. Sagemcom is a brand name. What is the model?
If it does wifi, then it is probably also a router. Two routers on your network can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
Iy may be possible to put the modem/router into modem only (bridge) mode and then to use the R6400V2 as the router. But sometimes it is just easier to put the R6400V2 into AP mode. But that has its own drawbacks:
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR SupportUnfortunately, it still isn't clear to me what your problem is and what you are trying to do.
Hi michaelkenward , Apologies, I may have confused when trying to answer questions both from yourself and others.
I like the idea of a RBK30 next to the isp modem (which would still be powered to service the voip).
As far as putting the r6400v2 as the router...it current coverage is not quite there (though as you stated, this could be due to having TWO routers).
You stated about applying a bit more effort before buying a rbk30....how would you do this...I have already moved and reconfigured many associated items (like a power line adapter, foxtel service)...and as mentioned I currently need the sagemcom ( 'gateway 3864 v3 AC ) for VOIP.
My aim is to extend the coverage of the current 'config'...the NBN (in australia) is a mandated (by govt) connection...that has congestion and regular drop outs...(hope this clarifies my issue and intention).
FYI I have a single storey, four bedroom house on a 540 Sq.Meter block
Looking forward to further advises
