alphadoc
Apr 05, 2021Follower
Extending internet service
I'd like to extend internet service from my house to another building 350' away. Is it possible to do this by using a fiber optic cable between the two builidings, with an ethernet <--> fiberoptic d...
Apr 05, 2021Guru - Experienced User
You could do something like that but if you're inexperienced with fibre, another option might be using a point to point system like netgear airbridge. Might end up cheaper to buy a set of those versus the fibre and converter boxes. (Unsure on cost but its worth comparing)
