thehop
Apr 19, 2020Aspirant
Extending my Orbi network to my dock
Let me start by saying I am "network stupid." That's why I'm here asking what I hope are easy questions for you guys. I have the Orbi mesh router system in my home. I have the RBR50 connected to ...
Apr 19, 2020Guru - Experienced User
Yes you can just get a regular extender or access point. If you get an extender, just make sure it supports access point mode. The cheap base models don't.
But you can also pick up a used/new/refurbed satellite to use. this would at least keep everything on the orbi network.
And I'd recommend bringing the satellite inside for the winter. The large temp changes are usually what cause the issues.
did you check the power supply on the broken device? The rbr50 and rbs50 should use the same power supply. Try plugging the rbs in with the rbr's power supply and see if its a power supply issue.
- thehopApr 19, 2020Aspirant
Thank you for your response. It is truly appreciated! I brought the broken device into the house and plugged it in about 6' from the Orbi router. Recycled, etc, but still no light from the broken device. The power light is on but I get nothing. I don't see any "outdoor" access points from Netgear other than the RBS50Y, which doesn't work for me. Rather than spend money on another Orbi satellite, even a less expensive refurbished one, I think I'll try the wired access point now that you have confirmed that should work for me. Thank you very much for your help.
- plemansApr 19, 2020Guru - Experienced User
did you try swapping power supplies?
Or once you've tried that, even opening up the broken orbi to see if there's any visible issues. maybe corrosion on the power plug/board from the outdoors?
I simply brought it indoors from the dock and plugged it into a wall outlet. I don't know how to open up an Orbi device and if I did, I wouldn't be confident to plug it in again. I am also "electricity stupid." With my lack of knowledge I think I'm better off just buying an access point that is rated for the outdoors. Thank you!
