heathyrnance
Nov 12, 2019Initiate
Extending Orbi to barn 300 feet away
We have the Orbi RBR50 mesh system with 2 satellites. One satellite is in a 2nd story window with direct sight to our barn 300 feet away. I've tried to use a Netgear Powerline adapter to extend cov...
CrimpOn
Nov 12, 2019Guru - Experienced User
heathyrnance wrote:We have the Orbi RBR50 mesh system with 2 satellites. One satellite is in a 2nd story window with direct sight to our barn 300 feet away. I've tried to use a Netgear Powerline adapter to extend coverage from house to barn (ethernet cable from satellite in window - ethernet cable to outlet in barn. Both on same electric meter. Yes, it did work when I tried it in the house near each other).
As others have pointed out, 300ft. is too far for an Orbi 5GHz backhaul signal and may be too far for PowerLine. Others have had success with a pair of Ubiquiti Nano Stations (there are several models. Search the forum.)
I would investigate a point to point system. There's many different models you could choose from. I've never used one but know of someone who used an engenius model that worked well for round 600ft.
