heathyrnance
Nov 12, 2019Initiate
Extending Orbi to barn 300 feet away
We have the Orbi RBR50 mesh system with 2 satellites. One satellite is in a 2nd story window with direct sight to our barn 300 feet away. I've tried to use a Netgear Powerline adapter to extend cov...
Orbi-Roc
Nov 13, 2019Luminary
Hi heathyrnance . Have you considered extending your network with an Orbi RBS50Y outdoor satellite? It seems to me that if installed halfway between the house and the barn, with Daisy-Chain topology enabled, it could do the trick. Perhaps a wise thing to do would be to query this Community on this outdoor Orbi and see what other users are saying about it. Amazon reviews seem to be pretty positive. Good luck!
Nov 13, 2019Guru - Experienced User
the RBS50Y wouldn't reach (as you said) and would be in the middle. So they'd still need to add something in the barn on the other end. it'd probably work to go house----rbs50y-----AP in barn but it might be expensive. Many point-point systems have an AP built into them and many tend to be cheaper than the RBS50Y.
