J-L-B
Apr 29, 2020Aspirant
Extending ORBI WIFI using Apple Time Captule
Hi, An ORBI is setup in my house and I have an Apple Time Capsule which I want to use to extend the ORBI signal in my house. Currently the ORBI LAN to connected to the Applie Time Capsule WAN port Nee...
Apr 29, 2020Guru - Experienced User
You can try Extend to see if it connects to the Orbi WiFi. I may not.
Please contact Apple support and review installation documentation on how to setup there devices.
Which Orbi system do you have? Orbi should be enough to cover and provide wifi signals.
