OrbiRocks
May 03, 2020Guide
Extending Orbi with EX3700
I have a Netgear EX3700 extender that I'd like to use as an Extender and install in a nearby shop building and connect it to the closest sattelite on my Orbi RBK23 system. But it doesn't seem to be w...
CrimpOn
May 03, 2020Guru - Experienced User
OrbiRocks wrote:I have a Netgear EX3700 extender that I'd like to use as an Extender and install in a nearby shop building and connect it to the closest sattelite on my Orbi RBK23 system. But it doesn't seem to be working. Does the EX3700 have to connect to the main Orbi (which is in AP mode)? I can get it to connect to the sattelite, but then it has no internet connection. It seems like it works when I put it near the main unit, but it doesn't seem to want to daisy chain off the closest sattelite.
If I bought a Netgear AC750 (or AC1200) would those be able to daisy chain off my closest sattelite?
This is the product, correct: https://www.netgear.com/support/product/EX3700.aspx
When you follow the setup video and connect it to the satellite (in the same room to reduce travel time), and then connect something to the extender SSID, does the device "connect"? Does it get an IP address?
I have connected a similar Netgear extender to my Orbi when I was investigating an IoT device that was difficult to set up. Worked fine. Although to be honest, I did connect it to the router because I was doing the experiment in my "lair".
OrbiRocks
May 03, 2020Guide
Yes, that is the device. I can connect to it after I have set it up, but I have no internet.
- CrimpOnMay 03, 2020Guru - Experienced User
OrbiRocks wrote:Yes, that is the device. I can connect to it after I have set it up, but I have no internet.
Does the device get network setup information:
- IP address?
- Gateway IP address?
- DNS IP address?
Since the Orbi is in Access Point (AP) mode, the Gateway and DNS IP addresses should be identical to every other device, and the device IP address should be in the same "subnet" as the other WiFi devices.
- OrbiRocksMay 03, 2020Guide
Does anyone know if the Netgear AC750 (or AC1200) are able to daisy chain off an Orbi Sattelite, and act as another sattelite ?
OrbiRocks wrote:Does anyone know if the Netgear AC750 (or AC1200) are able to daisy chain off an Orbi Sattelite, and act as another sattelite ?
The answer to this is very clear. No way. Never. Can't be done. Only an Orbi "satellite" has the firmware needed to act as a "satellite".
I still think it should be possible to connect an "extender" as an "extender". The "satellite" functions simply will not apply. For example, when a device "roams" from one Orbi toward another, the Orbi's communicate and use WiFi standard protocols to suggest that the device move from one access point to the other. Not going to happen with the extender.
