OrbiRocks
May 03, 2020Guide
Extending Orbi with EX3700
I have a Netgear EX3700 extender that I'd like to use as an Extender and install in a nearby shop building and connect it to the closest sattelite on my Orbi RBK23 system. But it doesn't seem to be w...
OrbiRocks
May 03, 2020Guide
Yes, that is the device. I can connect to it after I have set it up, but I have no internet.
CrimpOn
May 03, 2020Guru - Experienced User
OrbiRocks wrote:Yes, that is the device. I can connect to it after I have set it up, but I have no internet.
Does the device get network setup information:
- IP address?
- Gateway IP address?
- DNS IP address?
Since the Orbi is in Access Point (AP) mode, the Gateway and DNS IP addresses should be identical to every other device, and the device IP address should be in the same "subnet" as the other WiFi devices.
- OrbiRocksMay 03, 2020Guide
Does anyone know if the Netgear AC750 (or AC1200) are able to daisy chain off an Orbi Sattelite, and act as another sattelite ?
- CrimpOnMay 03, 2020Guru - Experienced User
OrbiRocks wrote:Does anyone know if the Netgear AC750 (or AC1200) are able to daisy chain off an Orbi Sattelite, and act as another sattelite ?
The answer to this is very clear. No way. Never. Can't be done. Only an Orbi "satellite" has the firmware needed to act as a "satellite".
I still think it should be possible to connect an "extender" as an "extender". The "satellite" functions simply will not apply. For example, when a device "roams" from one Orbi toward another, the Orbi's communicate and use WiFi standard protocols to suggest that the device move from one access point to the other. Not going to happen with the extender.
Do you know this for a fact? The two Netgear models I posted say they work with Mesh systems
.NETGEAR WiFi Mesh Range Extender EX6150
