OrbiRocks
May 03, 2020Guide
Extending Orbi with EX3700
I have a Netgear EX3700 extender that I'd like to use as an Extender and install in a nearby shop building and connect it to the closest sattelite on my Orbi RBK23 system. But it doesn't seem to be w...
May 04, 2020Guru - Experienced User
Well that was quick...
- OrbiRocksMay 04, 2020Guide
Seems like my post dissapeared??
I guess I could retype it all. Spent quite a bit of time talking with support and learned some new info.
Not sure what I'm doing wrong here. Posted reply two times, and both times it has been deleted. I didn't think I said anything negative, not sure I understand why my posts are being removed.
- FURRYe38May 04, 2020Guru - Experienced User
Ya I know. I was reading thru your responce. Nothing negative.
Thought the 1st level phone support may not be aware of a beta or a non release FW version that was given to a few that had the EX3700.
You might ask Christian_R to see if this is still available. It's up to you though. In mean time, connect the EX in AP mode if you need additional signal, though it won't be apart of the MESH system.
