OrbiRocks
May 03, 2020Guide
Extending Orbi with EX3700
I have a Netgear EX3700 extender that I'd like to use as an Extender and install in a nearby shop building and connect it to the closest sattelite on my Orbi RBK23 system. But it doesn't seem to be w...
OrbiRocks
May 04, 2020Guide
Not sure what I'm doing wrong here. Posted reply two times, and both times it has been deleted. I didn't think I said anything negative, not sure I understand why my posts are being removed.
CrimpOn
May 04, 2020Guru - Experienced User
OrbiRocks wrote:Not sure what I'm doing wrong here. Posted reply two times, and both times it has been deleted. I didn't think I said anything negative, not sure I understand why my posts are being removed.
You are probably more careful than I am. Several times I have created (very sophisticated and witty) posts and neglected to scroll down the page and click on "Post". I have so many browser windows open at one time and keep switching back and forth between them as I look up URL's to include in my message, and more windows so that I can scroll through the past entries in a post, that I get confused and close a bunch of windows including the one with that fabulous post. Later, I say, "where the heck is my post?"
If some omniscient moderator were deleting posts, I can point you to dozens that I would rather "went away."
- CrimpOnMay 04, 2020Guru - Experienced User
Is there a time constraint for resolving this issue? Amazon says the Netgear EX3700 may be available starting May 6. I just saved $40 by not being able to go out to dinner, so I'd love to have one of these to play with. They are definitely "old technology", but what the heck.
The newer "mesh" extenders cost quite a bit more, and my Orbi provides all the coverage I need.
So, if the decision has to be made soon, or other products are being considered, there's not much point getting one.
