Apple21
May 12, 2020Aspirant
Extension to guest house
I have the Orbi Tri-band Whole Home Mesh WiFi System, with Wall Plugs (RBK33) system, I have extended it to the guest house 400 feet away with two satellites and it works. The problem is that the...
Apple21
May 13, 2020Aspirant
Thank you. So you think that would be better than an additional router on the AP mode.
I looked up the Airbridge and it seems to be perfect. Do I need to buy two or just one and that will connect to the satellites in guest house.
Thank you.
plemans wrote:I'm surprised it even works. 400ft is a long way for a standard wireless setup. A point to point system wouldn't have issues.
that's probably why you're having issues.
You could try something like netgear's airbridge to connect the 2 buildings and then connect a satellite in the other building.
Apple21
I apologize if I was not clear. Currently I have two satellites in the guest house.
Ty.
