Apple21
May 12, 2020Aspirant
Extension to guest house
I have the Orbi Tri-band Whole Home Mesh WiFi System, with Wall Plugs (RBK33) system, I have extended it to the guest house 400 feet away with two satellites and it works. The problem is that the...
May 13, 2020Guru - Experienced User
Apple21 wrote:Thank you. So you think that would be better than an additional router on the AP mode.
I looked up the Airbridge and it seems to be perfect. Do I need to buy two or just one and that will connect to the satellites in guest house.
Thank you.
In point to point mode it takes 2. one at each end. You'd still need the 2 satellites in the guest house but it'd provide a better backhaul than trying to reach that far with standard satellites.
Apple21
May 13, 2020Aspirant
Thank you. So I need to purchase two of these?
https://www.amazon.com/NETGEAR-multi-point-connectivity-Management-WBC502-100NAS/dp/B083R37W26
- plemansMay 13, 2020Guru - Experienced Userfor it to work properly yes. there are cheaper systems on amazon. you just need to search for point to point system
