ddonjon
Mar 27, 2019Follower
External Storage on Orbi RBK50 Router
I have just purchased the Orbi AC3000 (RBK50) router and satelitte and was hoping to connect some external storage to the wireless network for movies, photos etc. My previous router was an Apple Air...
Mar 27, 2019Guru - Experienced User
Real NAS devices work with Orbi that have LAN connections. Orbi doesn't support USB drives at this time. Not sure if it ever will.
You can check out some USB to LAN adapters to see if this would help connect the USB drive to a network LAN connection. I recommend finding a actual NAS system to connect for long term storage solutions and better flexibility for connections.
- CoolNKJun 18, 2019Initiate
Such a High Cost device, should have basic capability of attaching any external storage drvie or USB drive to support/connect using Wi-Fi. I see many of other competitors router and modem has this capability.
I would really appreciate Netgear Team to provide a FIX for all existing Netgear ORBI customers, else you will certainly lose the attention and market soon.- ekhalilJun 19, 2019MasterYou can wire your AirPort Extreme to Orbi, set the AirPort Extreme in AP mode (no radio) and connect your USB drives to the AirPort.
I use an AirPort TimeCapsule in this configuration and it works flawlessly. - FURRYe38Jun 19, 2019Guru - Experienced User
People have been asking about this from NG for past few years. NG hasn't made any new features for it and I presume they may not being this far into the 1st gen Orbi. Maybe next gen Orbi however no info currently. Market for Orbi has been working thus far, with or with out USB storage support. IMO LAN NAS is better for storage vs USB storage.
I recommend trying the suggestion that ekhalil mentioned with your other router to get USB storage solution going in mean time.
CoolNK wrote:Such a High Cost device, should have basic capability of attaching any external storage drvie or USB drive to support/connect using Wi-Fi. I see many of other competitors router and modem has this capability.
