theyoungsavage
Mar 31, 2022Initiate
External Wifi range RBS50
I have an RBR50 router and two RBS50 satellites in my home, successfully dealing with wifi dead-spots, but the range on the satellite does not reach my garage (I sometimes have intermittent connectio...
theyoungsavage
Hi Plemans
Thanks for the reply. Not sure the correct terminology, but by 'plug top extender' I meant the plug-in 'Powerline' units (usually a transmitter that connects to the router and a receiver that emits wifi) that uses the existing electrical wiring. I will probably go ahead and buy one but I hoped someone would recommend something that is suited to the ORB system rather than me pick something at random. I'm presuming that I could just connect the transmitter to an ethernet socket on the RBS50 and it will work as if plugged directly into my router...
Cheers
Mar 31, 2022Guru - Experienced User
Powerline does work but some places/setups it doesn't function that great. If you do buy one, make sure to get one from a place with a good return policy in case your setup isn't optimal for it.
You can always use the powerline to function as a wired backhaul for the orbi. I've seen users do that.
