hcch's avatar
hcch
Extra satélite compatibles
Hi I wonder if I can use other kind of satellites besides the RBR20's for my RBK43.   I understand the difference with the big 50 satélite will be speed but I do not know if I can use it no matter ...
  • plemans's avatar
    Jul 11, 2020
    You can use these:
    rbs20
    rbw30
    rbs40
    rbs40v
    rbs50
    rbs50y
    they'll all work. The 50 series will function at the lower backhaul that the rbr40 uses.
