numzie77
Dec 26, 2022Guide
Extra satellite for RBK40
Hi I have an RBK40 setup (RBR40 router and RBS40 satellite). I would like another satellite, as we struggle a bit in the end of our house even though it's not that big. Which satellites (beside...
CrimpOn
Dec 26, 2022Guru - Experienced User
Satellites compatible with the RBR40 router include:
- RBS50
- RBS40
- RBS30
- RBS40V
None of the AX or "Pro" satellites integrate with the original WiFi5 systems.
- KevinLiTDec 26, 2022NETGEAR Moderator
Hello numzie77,
Welcome to the Netgear Community!
The Orbi router can not be used as a satellite.
Please see the link below for our compatibility cart for all satellites that are compatible with your RBR40:
Which Orbi routers and satellites are compatible? | Answer | NETGEAR Support
Best,
Kevin
Community Team
