numzie77
Dec 26, 2022Guide
Extra satellite for RBK40
Hi I have an RBK40 setup (RBR40 router and RBS40 satellite). I would like another satellite, as we struggle a bit in the end of our house even though it's not that big. Which satellites (beside...
CrimpOn
Dec 26, 2022Guru - Experienced User
Satellites compatible with the RBR40 router include:
- RBS50
- RBS40
- RBS30
- RBS40V
None of the AX or "Pro" satellites integrate with the original WiFi5 systems.
KevinLiT
Dec 26, 2022NETGEAR Moderator
Hello numzie77,
Welcome to the Netgear Community!
The Orbi router can not be used as a satellite.
Please see the link below for our compatibility cart for all satellites that are compatible with your RBR40:
Which Orbi routers and satellites are compatible? | Answer | NETGEAR Support
Best,
Kevin
Community Team
