stevedavis
Jan 16, 2021Aspirant
Extra satellite or second router
Currently with Comcast and a 500 mbps plan. I have the RBK50 with one satellite. One of the kids rooms seems to have more issues with wifi due to distance and the number of walls the signal needs t...
- Jan 21, 2021
correct. If you have moca in the xb6, then you'd just need a compatible adapter where you wanted service.
Jan 16, 2021Guru - Experienced User
Most isp's only allow 1 modem unless you pay for another line.
But you could use a moca adapter (ethernet over coax)
Or add a satellite. either option would work.
The RBS40V has been on sale lately on amazon for pretty reasonable price. And it might be beneficial for the added coverage.
- stevedavisJan 18, 2021Aspirant
If I use a moca adapter, other than the router connection do I need to use one at every cable connection or can I just use them where needed? Wasn't sure if I needed one where I have the main cable box.
Thanks
- plemansJan 18, 2021Guru - Experienced User
You can use one where ever needed. Just make sure the coax cables are linked. I've seen someone who had them not connected in the utility room and couldn't figure out why the system wouldn't work.
- stevedavisJan 19, 2021Aspirant
One more question as I'm thinking the moca adapters might be the way to go. If I set up the moca adapter on the Xfi modem and main Orbi, will the satellite require an adapter too? Just don't have a good spot for the satellite where there's a coax outlet.
Appreciate your help!
- plemansJan 19, 2021Guru - Experienced User
I guess I'd like a little more clarity.
Moca adapters basically allow you to use a coax line as ethernet.
You only really need 2. One on the primary router and then 1 where you want a connection. You can add others if your wanting more hardwired connections somewhere.
Your orginal question was about adding another satellite. You might not need a moca adapter if you use another satellite.
