stevedavis
Jan 16, 2021Aspirant
Extra satellite or second router
Currently with Comcast and a 500 mbps plan. I have the RBK50 with one satellite. One of the kids rooms seems to have more issues with wifi due to distance and the number of walls the signal needs t...
- Jan 21, 2021
correct. If you have moca in the xb6, then you'd just need a compatible adapter where you wanted service.
stevedavis
Jan 18, 2021Aspirant
If I use a moca adapter, other than the router connection do I need to use one at every cable connection or can I just use them where needed? Wasn't sure if I needed one where I have the main cable box.
Thanks
Jan 18, 2021Guru - Experienced User
You can use one where ever needed. Just make sure the coax cables are linked. I've seen someone who had them not connected in the utility room and couldn't figure out why the system wouldn't work.
