stevedavis's avatar
stevedavis
Extra satellite or second router
Currently with Comcast and a 500 mbps plan.  I have the RBK50 with one satellite.  One of the kids rooms seems to have more issues with wifi due to distance and the number of walls the signal needs t...
  • plemans's avatar
    Jan 21, 2021
    correct. If you have moca in the xb6, then you'd just need a compatible adapter where you wanted service.
