MP1987
Nov 17, 2021Aspirant
Extremely slow CBR40 Speeds, need help
I have the "Ultra Fast" 900mbps Xfinitity plan with a CBR40 modem/router and RBS20 satelite. I've never seen speeds quite near 900, but in the past it's been quite good (at least 300-400mbps over Wi...
Nov 17, 2021Guru - Experienced User
If you have a PC or laptop that does not have a ethernet port, you can get a USB to ethernet port adapter to help with testing wired speeds.
The CBR40 should see near 800-900Mbps depending upon if ISP supports on DOCSIS 3.0 it and all 32 channels are locked in. Most ISP now days require a DOCSIS 3.1 modem for 1Gb services.
MP1987
All the devices I've tried doing a speed test on are on the 5ghz network.
What do you mean by "all 32 channels are locked in" ?
- FURRYe38Nov 18, 2021Guru - Experienced User
The channels seen on the Cable Connection Status page.
Will look similar to whats seen here:
What wifi devices do you have connected to the CBR?
- MP1987Nov 18, 2021Aspirant
Oh okay gotcha. I cannot load the Cable Connection page on my laptop over wifi unfortunately. I'm not sure why. Every other page on the router login loads fine.
I actually have 18 wifi devices connected. Most of which are smart home devices (cameras, hubs, smart thermostat etcetera).
One thing to try when you have time and when wifi isnt' needed, Turn off all but one or two wifi devices and see if this changes anything as well. 18 devices shouldn't impact anything however you never know.
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026Would be good to get a USB to ethernet adapter as well to check wired speeds thru the CBR.
