MP1987
Nov 17, 2021Aspirant
Extremely slow CBR40 Speeds, need help
I have the "Ultra Fast" 900mbps Xfinitity plan with a CBR40 modem/router and RBS20 satelite. I've never seen speeds quite near 900, but in the past it's been quite good (at least 300-400mbps over Wi...
MP1987
All the devices I've tried doing a speed test on are on the 5ghz network.
What do you mean by "all 32 channels are locked in" ?
Nov 18, 2021Guru - Experienced User
The channels seen on the Cable Connection Status page.
Will look similar to whats seen here:
What wifi devices do you have connected to the CBR?
- MP1987Nov 18, 2021Aspirant
Oh okay gotcha. I cannot load the Cable Connection page on my laptop over wifi unfortunately. I'm not sure why. Every other page on the router login loads fine.
I actually have 18 wifi devices connected. Most of which are smart home devices (cameras, hubs, smart thermostat etcetera).
- FURRYe38Nov 18, 2021Guru - Experienced User
One thing to try when you have time and when wifi isnt' needed, Turn off all but one or two wifi devices and see if this changes anything as well. 18 devices shouldn't impact anything however you never know.
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026Would be good to get a USB to ethernet adapter as well to check wired speeds thru the CBR.
- MP1987Nov 21, 2021Aspirant
So I bought a usb/ethernet adapter and it turns out I'm seeing speeds of over 600 mbps when directly wired.
I still can't load the "cable connection" page under the router login, even when wired.
So it seems it's just my wifi speeds that are extremely slow. Any advice?
