MP1987
Nov 17, 2021Aspirant
Extremely slow CBR40 Speeds, need help
I have the "Ultra Fast" 900mbps Xfinitity plan with a CBR40 modem/router and RBS20 satelite. I've never seen speeds quite near 900, but in the past it's been quite good (at least 300-400mbps over Wi...
MP1987
Nov 21, 2021Aspirant
So I bought a usb/ethernet adapter and it turns out I'm seeing speeds of over 600 mbps when directly wired.
I still can't load the "cable connection" page under the router login, even when wired.
So it seems it's just my wifi speeds that are extremely slow. Any advice?
Nov 23, 2021Guru - Experienced User
What wireless devices are you using when speed testing?
What channels are you using?
Be sure Beamforming and MIMO(MIMO may or may not be needed) and WMM are enabled. Under Advanced Tab/Advanced Settings/Wireless Settings. You can disable MIMO as a test to see if this changes anything. Set 20/40Mhz Coexistence to 40Mhz only.
- Rac1ngSnak3Dec 31, 2021Aspirant
I'm in a similar situation. Xfinity 600 mbps plan connected to Orbi CBR40 and 2 satellites (RBW30 and RBS50Y). On Ethernet (AppleTV, Speedtest app) directly connected to CBR40 I actually get better than advertised speeds at 715 mbps (don't tell Xfinity). But when I use a WiFi device I'm maxed out at about 300 mbps (280-315). Beamforming is enabled and MIMO is enabled, and 20/40 MHz coexistence is disabled. WiFi devices are on 5GHz and "connected" to the CBR40. 8 devices are on the WiFi network. WiFi space is pretty dense as we're in an apartment complex but S/N seems good inside our apartment. I'd expect WiFi speeds to be a little higher maybe in the 500 mbps range.
What's the fastest speeds people have seen with their CBR40 on WiFi?
- FURRYe38Jan 02, 2022Guru - Experienced User
The speeds you are seeing are generally normal for something on 5Ghz AC. Most devices max out at 300-500 depending upon there design. If your in a noise wifi environment, this can cause problems as well. Try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
- Rac1ngSnak3Jan 02, 2022Aspirant
FURRYe38 wrote:The speeds you are seeing are generally normal for something on 5Ghz AC. Most devices max out at 300-500 depending upon there design. If your in a noise wifi environment, this can cause problems as well. Try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
Rac1ngSnak3 wrote:I'm in a similar situation. Xfinity 600 mbps plan connected to Orbi CBR40 and 2 satellites (RBW30 and RBS50Y). On Ethernet (AppleTV, Speedtest app) directly connected to CBR40 I actually get better than advertised speeds at 715 mbps (don't tell Xfinity). But when I use a WiFi device I'm maxed out at about 300 mbps (280-315). Beamforming is enabled and MIMO is enabled, and 20/40 MHz coexistence is disabled. WiFi devices are on 5GHz and "connected" to the CBR40. 8 devices are on the WiFi network. WiFi space is pretty dense as we're in an apartment complex but S/N seems good inside our apartment. I'd expect WiFi speeds to be a little higher maybe in the 500 mbps range.
50% power dl speed was 275 mbps
100% power dl speed was 314 mbps
