MP1987
Nov 17, 2021Aspirant
Extremely slow CBR40 Speeds, need help
I have the "Ultra Fast" 900mbps Xfinitity plan with a CBR40 modem/router and RBS20 satelite. I've never seen speeds quite near 900, but in the past it's been quite good (at least 300-400mbps over Wi...
Rac1ngSnak3
Dec 31, 2021Aspirant
I'm in a similar situation. Xfinity 600 mbps plan connected to Orbi CBR40 and 2 satellites (RBW30 and RBS50Y). On Ethernet (AppleTV, Speedtest app) directly connected to CBR40 I actually get better than advertised speeds at 715 mbps (don't tell Xfinity). But when I use a WiFi device I'm maxed out at about 300 mbps (280-315). Beamforming is enabled and MIMO is enabled, and 20/40 MHz coexistence is disabled. WiFi devices are on 5GHz and "connected" to the CBR40. 8 devices are on the WiFi network. WiFi space is pretty dense as we're in an apartment complex but S/N seems good inside our apartment. I'd expect WiFi speeds to be a little higher maybe in the 500 mbps range.
What's the fastest speeds people have seen with their CBR40 on WiFi?
Jan 02, 2022Guru - Experienced User
The speeds you are seeing are generally normal for something on 5Ghz AC. Most devices max out at 300-500 depending upon there design. If your in a noise wifi environment, this can cause problems as well. Try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
- Rac1ngSnak3Jan 02, 2022Aspirant
FURRYe38 wrote:The speeds you are seeing are generally normal for something on 5Ghz AC. Most devices max out at 300-500 depending upon there design. If your in a noise wifi environment, this can cause problems as well. Try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
Rac1ngSnak3 wrote:I'm in a similar situation. Xfinity 600 mbps plan connected to Orbi CBR40 and 2 satellites (RBW30 and RBS50Y). On Ethernet (AppleTV, Speedtest app) directly connected to CBR40 I actually get better than advertised speeds at 715 mbps (don't tell Xfinity). But when I use a WiFi device I'm maxed out at about 300 mbps (280-315). Beamforming is enabled and MIMO is enabled, and 20/40 MHz coexistence is disabled. WiFi devices are on 5GHz and "connected" to the CBR40. 8 devices are on the WiFi network. WiFi space is pretty dense as we're in an apartment complex but S/N seems good inside our apartment. I'd expect WiFi speeds to be a little higher maybe in the 500 mbps range.
50% power dl speed was 275 mbps
100% power dl speed was 314 mbps
